Again, a strange problem
EnthusiastBuild
Level 12
Dear ROGers
And again I am having a strange problem.
About a month ago it started. Everytime Windows 8.1 makes an update and i restart my PC, keyboard and mouse (Razer Blackwidow, Razer Taipan USB both) will work in BIOS but as soon as the login screen comes they power off and I can't type anything.
I always have to set back my system via recovery and then it works again.
What the heck is this, I googled and googled but found no solution for me, I hope someone here can me help, it is freaking me out.
Sincerely
EnthusiastBuild
CORSAIR 900D
ASUS MAXIMUS VI FORMULA
INTEL I7 4770K @ 4.5 GHZ
CORSAIR DOMINATOR PLATINUM 16GB @ 2400MHZ
SLI EVGA GTX 780 SC ACX
SSD SYSTEM: CORSAIR FORCE GT 120GB
SSD APPS: CORSAIR FORCE GT 240 GB
HDD STORAGE: WD BLACK 2TB
CORSAIR AX860I PSU
CORSAIR H100I 4 x SP120 HP
23 REPLIES 23
EnthusiastBuild
Level 12
Anyone?
CORSAIR 900D
CORSAIR AX860I PSU
Myk_SilentShado
Level 15
What USB ports are you using mate? 2.0 or 3.0?
CloudD901
Have you tested plugging in a different mouse/keyboard and log into Windows to see if your current set begins working again? If not a driver issue, could be USB 3.0 issue as mentioned above.
EnthusiastBuild
Level 12
I am using usb 2.0 ports, just 1 3.0 for charging my cellphone sometimes 😞
CORSAIR 900D
CORSAIR AX860I PSU
CloudD901
Sounds more like a driver issue with the OS. Try another set of mouse/keyboard if possible so you can test more without doing a system recovery.
Myk_SilentShado
Level 15
I'd also try looking at Razer's Forums/Website to see if there are any new drivers for 8.1
abvolt
Level 11
I have used razer mice & keyboards for a long time and they have always had issues with their software, their mice are the worst with this problem. I have never found a fix. Check out their board and you'll see many many issues..
Current: MSI Xpower Gaming Titanium | 7700K | G Skill Ripjaws V 3000 16Gb | 960 EVO 500Gb | Intel 730 480Gb | Seasonic 1000 Platinum |
NZXT X62 | Acer XB270HU | EVGA 1080 ti FTW3
Secondary: R4BE | 4930K | G.SKILL 2400 16GB | Corsair AX 1500i
Intel 730 240GB + 480GB | EVGA GTX780 ti sli kpe | Custom H20
EnthusiastBuild
Level 12
I switched the mouse, same problem occured with a steelseries.
Its so bad now i have to restore it every time I reboot the system when installed the antivirus again and reebot
CORSAIR 900D
CORSAIR AX860I PSU
EnthusiastBuild
Level 12
It still happens, is there a way to reset all the usb?
CORSAIR 900D
CORSAIR AX860I PSU
