Acceptable PSU Voltage Drop ?
stock12to32
I have recently purchased a Lepa 1600W Full Modular PSU. I am getting some big drops in voltages even under small loads and I am wondering what is acceptable.
I have messaged Lepa a few days ago and still waiting on a return message from them.
I had a Antec 900W High Current Gamer PSU in my system and I would monitor my voltages and they would stay above the spec voltage.12v 5v 3.3v
I have a lot of stuff running in my computer with it being water cooled and I did not want to burn the Antec up so I purchased a Lepa 1600w PSU and when I put a load on the system through games I notice I big voltage drop. 12v = 11.74v, 5v = 4.8v and 3.3v = 2.8v.
Is that ok or should I be looking for a RMA on the PSU ?
I am judging this by how my Antec PSU performed, but the Lepa is gold certified.
I am getting the readings from AIsuite but it seemed to have done a good job on monitoring my Antec.
I have read the support page on the Lepa website and I have plugged PSU directly in to the wall. I made sure that I have spit the power load on each 12v rail and it did not make any difference.
3dMark11: P13350
http://www.3dmark.com/3dm11/6105510
System:
ASUS Crosshair V Formila BIOS 1703
AMD FX 8350 @ 25x 200 = 5Ghz (water cooled)
16Gb Patriot Vipper Xtreme DDR3 2133Mhz
x3 ATI HD6970 trifire @ 920Mhz GPU and 1400Mhz Memory
x2 128Gb Samsung 830 Series SSD RAID-0
128Gb OCZ Agility 3 SSD
x2 1Tb 7200RPM Hardrives RAID-0
LEPA 1600W PSU
Thermaltake Level 10 GT Snow
x3 27" ASUS LED LCD (eyfinity)
LG Blue-Ray
Logitech G110 Keyboard
Logitech G500 Mouse
Windows 8 64 bit
11 REPLIES 11
lenehan
I suggest to use a multimeter to test all the RAIL for the actual reading of your PSU.
Change is the law of life. And those who look only to the past or present are certain to miss the future.
I think you may have missed my last post. I no longer have this problem. I did test with a multimeter and got good results. Also found out why AISuite was reading low and it is fixed. Thank you though 😛
3dMark11: P13350
System:
LEPA 1600W PSU
LG Blue-Ray
Logitech G500 Mouse
Windows 8 64 bit
