9900kf 50/47 1.2v max temp 67 no delided, plus gskill 5000 mhz
Pun_VI
conclusions for 9900kf
better temperature. no need to delid.
better imc than 9900k
my system
9900kf 50/47 no delid. silicone TF8 with ek velocity cpu block and custom loop.
maximus xi apex
gskill royal 4600mhz oc to 5000 mhz
5 REPLIES 5
Falkentyne
Level 12
It's not the fact that the iGPU is disabled.
It's the new stepping. Notice the "R0"?
The 9900K's with iGPU will also get that stepping.
Temps are good, push it some more.
bass_junkie_xl
Level 12
is the 9900kf currently avalible ? is it a lot better then the 9900k ? or should i wait for the 9900 ks 5 ghz out of the box and hope for low volts ? whats your guys opinion ?
im on a 8700k @ 5.1 ghz and 4000 mhz cl-17 ram on a asus x hero am i missing out ?
Rig # 1 - 14900Ks SP-124 | 90 MC @ 6.0 GHZ | 5.2 R | 4.7 E | DDR5 48GB @ 8,600 c36 | Strix RTX 4090 | PG27AQN 1440P 27" 360 Hz G-Sync ULMB 2
Rig # 2 - 14900Ks-SP-118 | 89 MC @ 5.9 GHZ | 5.2 R | 4.7 E | DDR4 32GB @ 4,533 c16 | Strix RTX 3080 | Aoc 1080P 25" 240 Hz G-Sync
KF is a lot better than 9900k. Temperature is about 10 degrees decrease.
I'm not sure about temp whether it benefits from removing igpu or improve production quality .
If you're not in hurry, wait for KS results first.
IF you need it now go for KF. Because everyone will run at 5.0 ghz all core same as KS.
ps.
latest update ddr4 5360 mhz dual channel
ps.
wowzers man !!! look at that mem and cache benchmark 70 + k and under 35 ns @ 5300 mhz
1.5 v on cpu a little high but we are over clockers once they start to degrade we sell them and upgrade nice over clocks man
i bet arma 3 would see a massive fps boost from 5300 mzh ram specialy cl-18 !! could you do a fps benchmark with these settings ?
cpu @ 5 ghz and ram @ 3200 cl-14 1440p resultion no msaa
vs
cpu @ 5.3 ram @ 5300 mhz 1440p msaa off
test some fps games and show use the fps min / avg / max with that ram oc ?
making sure gpu usage is not 100% pegged before the test to see actual gains ?
