03-29-2016 07:36 PM - last edited on 03-06-2024 02:07 AM by ROGBot
04-01-2016 08:23 PM
Qwinn wrote:
Hmmm. Ok. So out of curiosity, what are your vcache, vinput and vccsa for your 1.17 4.5? LLC? Any other settings you think are working particularly well for you?
04-01-2016 09:43 PM
04-03-2016 12:23 PM
04-03-2016 01:59 PM
04-03-2016 02:09 PM
Gobe wrote:
I have to say that cekim's 1.118 Vcore at 4.5 GHz is nothing short of astounding.
I'm beginning to think that there's no telling with the I7 5960X. I have two of them and one is cherry-picked and is able to run individual cores easily at 4.9 GHz with the other 7 cores disabled, and a few of the cores can individually pull off 5 GHZ. The other CPU runs individual cores between 4.7 and 4.9 GHz (all under regular custom loop). From these numbers, you would think that the cherry-picked 5960X would be hands down a better overclocker. Yet, when I run RB H.264 Handbrake with the radiator in an ice bucket, I can get the "regular" 5960X up to around 4.86 GHz and the cherry-picked 5960X up to 4.90 GHz. Not totally stable for either, might get ten cycles on the bench before it crashes, might not get a single cycle run. Not much difference in the end between the $900 off-the-shelf CPU from Microcenter and the $1200 cherry-picked CPU. The cherry-picked 5960X can match core and cache up to about 4.8 GHz and the off-the-shelf 5960X needs to drop cache a couple hundred MHz, so I guess there is that difference.
Of course, I'm not done looking for sweet-spots in the various settings.
04-03-2016 02:17 PM
04-03-2016 05:06 PM
Martsmac1982 wrote:
Forgive my ignorance but what on earth are you guys using to cool your chips at 4.5+Ghz at such low voltages as you are using??? (my clocks wont stay stable above 4.4Ghz with anything less than 1.36v vcore which is ridiculous compared to 1.18v ish, i mean thats not even in the range of "I just got lucky in the silicon lottery with my chip" 1.18v at over 4Ghz is mental.
04-03-2016 05:17 PM
04-03-2016 05:29 PM
Martsmac1982 wrote:
Yeah thats what amazes me so much. I run with 3 540mm Rads and 1 pump in a single loop (although It shares the loop with 4x Titan X GPU's) and my temps (and clocks) are pathetic compared with yours on my 5960X back to the drawing board with my OC, good work though sir! Kudos to you!
