04-19-2015 07:53 AM - last edited on 03-06-2024 01:51 AM by ROGBot
05-09-2015 03:43 PM
05-09-2015 04:15 PM
05-09-2015 05:45 PM
05-09-2015 05:56 PM
05-09-2015 06:08 PM
Nate152 wrote:
vccsa is for instability of high speed ram, if your ram is stable you don't need to fool with this. I know our boards and cpu's are not the same but I had to set the vccsa voltage to 1.275v to get my ram stable at 2800MHz.
Vcore as you know needs to be bumped up for stability when overclocking your cpu.
LLC helps with vdroop and medium is the preferred setting, if you use ultra high or extreme it will overshoot the vcore you set.
Setting the cpu current capability as high as it will go will also help with overclocking your cpu.
This is all I have played with on my board and my cpu is running at 5.0 GHz with 1.45v
05-09-2015 06:03 PM
05-09-2015 06:14 PM
05-09-2015 06:19 PM
Nate152 wrote:
If you're shooting for 5.0GHz you could set the power phase to extreme but this will also make temps rise a little.
05-09-2015 06:32 PM
