4 pin fan header to 3 pin cable
Braindamage
Hey guys one question
How can i connect 4 pin fans to 3 pin cables used by my fan controller? The 4 pin are bigger and they wont fit on the 3 pin. Can i cut the plastic surrounding of the 3 pin male so that the 4 pin fan female can fit?
Thanks again
maximus V formula, 3770k @ 4.8, evga 780 classified hydro cooper,corsair 750D, corsair ax860, corsair dominator platinum 16gb @ 1866,128gb 840pro samsung , 240gb samsung evo, asus xonar essence sound card stx
Watercooling: Ek nickel clear cpu waterblock, Ek D5 pump, EK 140 reservoir, ekwb fittings, 1 360mm black ice SR1 radiator, 1 280mm black ice SR1, 3 Noctua NF-F12, 2 Noctua NF A14, 3 Corsair AF140 quiet
10 REPLIES 10
Retired
Not applicable
They are everywhere Arne, you know that, you only need to know the signs
