you need as well as me, to remove the heat shield on the cpu, replace the stock thermal past and you should be good for such overclocking.
i having the same headache, when i realized this, clocked down to 3800mhz at this time until i get some paste.
on the guide, we should achieve 4.5 @ 1.250v with extreme llc.
i plan to remove completely the heat shield plus removing the cpu socket locker thing. so the die is directly on my h80i base. so i can get lower LLC as well as lower voltage. or higher but i wont paste 4.5ghz/ but honestly its only for scoring past 4.2ghz is useless imo
let me know.
ps; thanks for the signature template
CASE LianLi PC V2000 MOBO Maximus V Gene CPU i5-3570k @ 4.5GHz RAM Corsair CMZ8GX3M2A1866C9 (4x4GB) CPU COOLER Corsair H80i SSD Intel C330 Serie 120Gb HDD 2Tb Seagate 5400Rpm PSU Silverstone OP1000 GPU EVGA GTX780 3gb GDDR5 HEADSET Corsair Vengeance 2000 7.1 OS Win 7 Pro 64 bits 😛
