Sorry.
I dont know why i think that BF3 will increase my temps. After I posted i played for about 40min to check it, and the temperatures were almost the same as SC2 Wings of Liberty
When I used to use AI Suite II my temps show like more 5 Celcius higher than SC2. I know that OCCT shows temps at all cores and AI Suite shows only CPU temp. That was the reason that i posted. So now, I am with different concept. Just show temperature increase on cores 0 and 3
Thanks anyway.
CPU: i5-3570k @ 4.400GHz. RAM: G. Skill Trident X @ 2400MHz CL10 (4x4GB) 10-12-12-31-2 MOBO: Maximus V Gene. BIOS:1903 CASE: Corsair Obsidian 800D. CPU COOLER: Thermaltake Water 3.0 Ultimate with 3 Noctua Fans NF-F12 industrial PPC-3000 PWM SSD: 2 x 256Gb Plextor M6S in RAID 0 HDD: 1 x 2Tb WD20EARX. PSU: Corsair Gold AX850 GPU: msi GTX 680 Twin Frozr iii OC 2gb GDDR5 Monitor: BenQ XL2410T. HEADSET: CM Storm Sirus 5.1 OS: Win 10 Pro 64 bits
