3 way sli problems maximus v extreme
charlie4985
iv recently bought a 3rd gtx670 for 3 way sli on the maximus v extreme board, but due to the size of my other gpu i cannot use the recommended slot 3, so there for i am using slots 1,2a and 4, unfortunatly my pc wont pick up the 3rd card as sli, just says dedicated physx, is it to do with the 3rd card being in slot 4 and not 3.
much appreciate help on the matter
Arne_Saknussemm
Level 40
Hi charlie4985
Does the third 670 have the same memory size as the other two. I take it you have a triple slot card in 2a...can you not move that down to slot 3?
