z170 Sabertooth, overclock failed, on every power on, with no overclocking...
kthejoker20
UPDATE SOLVE:
I had to manually set memory timings. The bios does not auto config the timing correctly.
YOU HAVE TO ENABLE XMP under ai tweaker. Thats the only way for the bios to run your memory at rated speeds.
As soon as I enabled that, it automatically configured the timings.
It's pretty stable now. Running at 3000mhz. Pretty sweet board now that it doesn't reset.
Everytime I power off the pc, and then power it back on I get a "Overlock failed press f1"
Then I go into the bios and select optimezed defaults.
When I select the settings, the bios freezes. Then I have to manually power off again.
The computer then boots and works the second time.
However, every power off, I still get the message and it appears the bios resets itself.
I am not overclocking anything, I am running at stock specs.
Any suggestions? I have the latest bios as of 11/2015
Nate152
Hello kthejoker20
Overclocking failed when not overclocking is likely due to high speed or high capacity ram and will need tweaking to get it fully stable.
Please list your complete system specifications.
Im using this ram
G.SKILL
Series Ripjaws 4 Series
Model F4-3000C15D-8GRBB
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231876&Tpk=N82E16820231876
But its running with stock bios settings at 2133.
Its unstable at that speed as well
Intel skylake core i7 6700k 4ghz
Onboard graphics and sound
Intel wifi card
Agility 3 ssd
UPDATE SOLVE:
