X99 Sabertooth Very High Temps for sensor 5 and 6 (100C+)! Normal?
tineras
https://imgur.com/a/AgzruzI
As you can see from the image, I have very high temperature readings on those two sensors. I am wondering if this is normal. #5 fluctuates like crazy and will go down to 0, then shoots back up. #6 hovers between 96C and 110C regardless of load. Oddly, running Prime95 causes #5 to stabilize at exactly 56C while the test is running. Goes crazy again as soon as I stop the test.
Thanks
Silent_Scone
Super Moderator
You would need to speak to Corsair and ask them what those two temps are in relation to. It's likely it's an erroneous reading, though
Arne_Saknussemm
Level 40
Those sensors don't exist so Corsair is just making it up...happens with other software too
