Will my 2400Mhz hyper x beast work with my formula z mobo?
DustyBoots
Hello to all!I have recently purchased a crosshair V-z and the memory i have selected is the kingston hyperx beast 2400 Mhz 16 gig memory kit.I know the whole amd should go with G skill or corsair but i thought i would give it a go just the same.P.S. I should have my mobo this week and i ordered it on the 5th,Was or is there a recall on the MoBo?Or is it just the fact that they flew off the shelves at such a rate that they are manufacturing more as i type.Anywho,Any comments are much appricated.
19 REPLIES 19
Well,I would love to give you fella's some feedback,But.I ordered my mobo on Feb 5 and amazon sent me an E-mail that say's the CHVF-Z will be out-of-stock till the end of april.I have all the other components for the build staring me in the face atm lmao...P.S. will keep everyone posted upon reciept and initial Boot!18154
Yeah, Amazon was also out of stock when I built my rig at the start if Feb... I ordered everything from Amazon except for the mobo, which I ordered from Newegg.. I think it was actually, like, $20 cheaper from "The Egg" than from Amazon. So it was kind of a win-win. 🙂 if it's still available from Newegg and you can still cancel your order from Amazon, then you might consider doing that... When I ordered, newegg also had free 3 day shipping, so it only arrived one day after the stuff from Amazon.
Just my two cents, though...
Good luck with your build.
CEJBLADE
when Its running really really good, love it just need to get it stable.
I keep you posted
Cej
HiVizMan
Level 40
I am going to keep an eye on this tread and see how it goes. I have the same kit of ram and system avaialbe to test if needed but it seems you guys have it covered. Just bare in mind that the CPU determines how well your ram can and does run. And that no two CPU's will behave the same. Or sadly perform the same.
Thanks HiVizman,
I have been playing for about 2 weeks now with the Bios trying to get the 2400MHZ stable sweet spot, I thought I had it with 8GB only but after 24hrs it went back to not recognizing the monitor on boot. I am going to spend all day tomorrow test this so I will keep you posted on how I fair.
Need to get all 16gb working 😉
Cheers
Cej
4Strings
I have the same setup too! (Well, almost, 2x8GB 2,133MHz) and I can't get it to run above 1,333... 😞 It's my first build, so maybe I'm doing something wrong? I tried to run at 1600 and 1866, but I get a BSOD saying something about memory after a short amount of time gaming or watching youtube videos... 😕 Any guide out there for first-timers on how to even set memory above 1333MHz on the CVFZ???
I'm currently out of town, but I'll jot down any advice and try it out once I get home. 🙂
Chino
Level 15
You can find a small guide in my signature for setting up your RAM to run at its advertised speed. I might have used a different platform but the concepts are the same. You'll just have to find the equivalent options in your BIOS. 😉
Note: On an AMD system, it's called D.O.C.P which is equivalent to X.M.P. 😛
THANKS CHINO!
I'll remember that for when I get back home. 🙂
Mjag01
Hello, first time posting. Looking for some help on OC. I have a Sabertooth X79, 3970K, and Kingstone Hyper X Beast , 2400mhz. Are there any settings I can use to get up to 2400mhz? Sometimes it works, but when the system goes into sleep, the memory red LED light stays on and I have to reboot. Any suggestion would be great. The settings for memory is: 11-13-13-30 and the CPU is OC at 4.5mhz and runs between 60c and 75c.
Thanks in advance for any help.
sectionate
Level 12
disable putting your ram to sleep, forgot what the option is called in my bios, I just know tis under ram settings somewhere
Crosshair IV 1090T 4093.7 - Crosshair V FX - 8350 Batch # 1243PGT 4.422MHz - 4816.08 MHz 1.5v - GSKILL F3-14900CL9D-8GBSR(x2)1087.6 11-12-10 1.5volts - ViewSonic VX2439wm - Acer GD235HZ - SyncMaster P2350 - PowerColor Red Devil RX 480 8GBD5-3DH/OC - Current Mode: 5760 x 1080 - (retired) ASUS GTX660DC2O2GD5 - Nvidia 3D Vision Wired - HAF 932 - Corsair HX850 - Corsair H100i - latest quakelive.com - Day thirteen 60fps - as always I'm powered by Futurelooks.com
