Will my 2400Mhz hyper x beast work with my formula z mobo?
DustyBoots
Hello to all!I have recently purchased a crosshair V-z and the memory i have selected is the kingston hyperx beast 2400 Mhz 16 gig memory kit.I know the whole amd should go with G skill or corsair but i thought i would give it a go just the same.P.S. I should have my mobo this week and i ordered it on the 5th,Was or is there a recall on the MoBo?Or is it just the fact that they flew off the shelves at such a rate that they are manufacturing more as i type.Anywho,Any comments are much appricated.
19 REPLIES 19
Chino
Level 15
Welcome to the ROG forums, DustyBoots.
As far as compatibility goes, the CHVF-Z supports this speed. But being able to run at those speeds depends hugely on the CPU.
Thank you for the welcome Mr.Chino!Great to be here. The new build is as follows :Crosshair formula V-z, 16 gigs of the 2400 kingston beast, corsair H-70 water cooler with 2 corsair high static fans , Corsair TX750M PSU, 2x gigabyte HD 7950's, AMD FX 8350 128 gig vertex4 SSD, 2x WD BC 500 gig HDD,
Chino
Level 15
Sweet build. The 8350 has a good chance of running 2400MHz RAM.
Just wondering. Where are you shopping for your parts? Maybe I can make a few recommendations. 😛
DustyBoots
I have bought everything from amazon as to date,just waiting on my mobo atm.But i would appriciate any feedback you might send my way!Also i have another question as well.Should i run my GPU's in the first and 3rd slots?Or the first and fifth slots to get the 16x x 16x?
jmoorez2001
first n third slot as i have them in the same order with 16 n 16 with evga 550 ti 2 gb video cards in sli on my chvfz board now
Awesome!Thanks for the info my friends!
Zka17
Level 16
First and third red slot, as per manufacturer's recommendation for a dual graphics setup... double check the manual when you get the board...
CEJBLADE
Hi Dusty
I have same setup as you and I am having problem trying to get the Memory up to 2400Mhz stable let me know if you have any joy
Thanks
Cej
Will do CEj,How do you like the system as of now overall?
