When booting up system, BIOS beep code help
Xarick
Hi. I got a crosshair v formula.
When I start up my system, I get different single beep sound lenghts. I am a bit worried that something's going on, so I decided to ask.
Usually, I get one short beep, then system boots up fine. But sometimes, I get one long beep, then system boots up, also fine.
Nothing else seems to differ, but this long beep has been happening only recently, and it's not all the time I power on the system, only some times.
Does anyone have any advice what could this possibly be? Should I be alarmed?
MeanMachine
Hi Xarick
Nothing much to worry about Xarick. Maybe just your keyboard if one short beep. (Try using another keyboard)
We owe our existence to the scum of the earth, Cyanobacteria
My System Specs:
MB:ASUS ROG Crosshair VII Hero/WiFi GPU:EVGA GTX 1080 sc PSU:Corsair AX-1200i
CPU:
AMD R7 2700X Cooler: Corsair Hydro H115i Case: Corsair Carbide 780t
Memory:G.Skill TridentZ F4-3200C14D-16GTZR SSD:Samsung 500GB 960 EVO M.2
[/HR]
