What to do with possible BIOS problems?
Moises2018
If the BIOS is corrupt or feel that the new BIOS is not performing well or giving problems can you :
1. Flash again with the new BIOS or
2. Flash with the older BIOS you use to have?
System specifications:
Motherboard: Maximus X Hero
BIOS Version
: 1401
OS: WIN 10 64 Bit
CPU: i7-8700K @3.7GHz
CPU Cooler: Corsair H100i Water Cooler
Memory:
G.SKILL TridentZ RGB Series 16GB (2 x 8GB) DDR4 3200 (PC4 25600)
Video Card: Gigabyte GeForce GTX 1080TI
SSD: Samsung 970 PRO M.2 (2280) 512GB &
Intel 335 Series 240GB (secondary drive)
Power Supply: Cooler Master Silent Pro 1000W
Hard Drives: WD 700GB & WD 300GB SATA
Optical Drives: 1 Asus Blu-Ray Drive & 1 DVD/RW Drive
5 REPLIES 5
Jim-M4EZ
3. Learn how to use the USB Bios Flashback feature of your ROG board, to perform 1 &/or 2 ...
4. Flash back to an earlier bios version with USB Bios Flashback ...
... & then flash forward to the "suspect" bios version again with EZ Flash 2.
5. Consider that there are some ROG folk, that follow a guideline to NEVER flash a bios update from within the OS ...
6. Under no circumstances should you ever interrupt the "re-start to re-set" process of a bios update ...
... you must allow the "re-set" procedure to run through the "re-set" process completely ...
... it will bring you to the F1 screen, or boot into Windows; depending on the bios version you have flashed.
7. Enjoy your new build !!! ... 😉
- M4EZ - 1: 3510 - 2: 1004 / i7-2600K / Redline 2133 16GB / Win7 Pro x64
- v.3510 / 8.0.0.1351 - v.8.1.0.1263 / 10.8.0.1303 - v.11.2.0.1006
- RevoDrive3x2 240GB - OS / Vector 256GB x2 RAID0 - OS / Vertex3 MI 120GB - OS / P'9230 3.0 2TB - B/U
- 9260-8i BBU - CacheCade Pro Vertex3 120GBx2 RAID0 SSD Caching - Const ES SAS RAID10 GHS - Data
- GTX580 3GB HC2 / Xonar Essence STX / ST1200G / TJ10B-W / ZR30w / SP 2500 2.1
- Water: Swiftech/Koolance/Tygon/EVGA/MIPS - Wind: SST/Noctua/Cougar
Moises2018
Wait, let me see if I understand correctly...
1. USB BIOS Flashback is only to get an older version of BIOS back?
And
2. EZ Flash 2 is to put a new version of BIOS on the board?
BIOS Version
: 1401
OS: WIN 10 64 Bit
Memory:
I would only use the rog flashback port only if you cant post at all and need to re-flash the bios...
I would recommend you use EZ Flash 2 within the bios to flash to new or older bios's, make sure youre USB drive is fat32 formated and use the biosrenamer tool to rename the bios file
Good luck..
Why would i ride the swing's when i've already been to DisneyLand..
HiVizMan
Level 40
Personally I am more interested in why or how one reaches that conclusion that the bios is not working well or corrupted. What behaviours led you to that conclusion?
I also agree on that point.
