What mini pcie wifi card for my Max V Gene
Vortimid
Just bought a Maximus V Gene desktop mobo and I need a wireless card.
I'd like to use the mini pcie slot.
Ideally, the wifi card would also have bluetooth on board.
I need the antenna(s) too.
Any suggestions on which one to buy and where?
4 REPLIES 4
kkn
Level 14
was there no mini pcie card in the boks?
Vortimid
Not on this model, just the msata / mpcie bracket.
Gabedamien
I got a used AR5BHB92 off of eBay, but that's because I built a hackintosh and wanted the most compatible components possible. That one doesn't have bluetooth, and there may be better chips for Windows anyway.
But for antenna, I can very much recommend the eBay seller "wifiexpert" (http://www.ebay.com/sch/wifi_expert/m.html) as he sells dual-band antenna pairs of various dBi with your length choice of included antenna - quite convenient.
Thanks for the rec. Antennas and pigtails I will get there.
Now, I need a good mpcie wifi recommendation.
