I hadn't started my machine in awhile (a few weeks). Anyhow I started it up tonight and I noticed that some applications were crashing or not even starting up. I decided to reboot to see if that fixed the issue. After it powered back on, I was stuck on the initial Asus red boot screen for several minutes, then I noticed my RAID config failed and then a few minutes later it said I had no readable disk. Perplexed I restarted again, and again it hung for 5 or so minutes at the splash screen. My RAID config failed, so I took the disks out of the array. This time I eventually got into Windows, however with the majority of applications now gone from erasing my array, it was fairly useless. However, I did notice that again Windows was acting strange- Explorer crashing, etc. I even tried to get into Parted Magic from a usb drive, but it wouldn't load properly (would just sit through the initialization process)...Though it worked fine on my laptop.
I cleared CMOS w/ no luck. Switched BIOS 1 to 2 w/ no luck. Flashed the latest BIOS w/ no luck. It just constantly hangs at the splash screen for several minutes before doing anything. I am also getting 64 on the debug LED, which is supposed to be "CPU DXE initialization is started". Does anyone have any ideas to a solution?
