VII Hero and 4690K Oc problem
JettyLT
Hey guys! So i set core ratio to 43 and core voltage to 1,20 and it doesnt show that my cpu speed is 4,3Ghz it just shows 3,5Ghz,Is
something wrong?
Using maximus VII Hero.Im noob for overclocking 😄 so dont judge me.
Backfire1
You will not see the over clock untill you stress the system. Another words it does not stay at 4300 MHZ. It will ramp up when under load. Also if your temps are to high it will throttle back. Try using AIDA64 to stress test and monitor your systems temps and MHZ.
