VI Impact no post power cycle
Ratty
I've just built 2 of these system fo myself and my brother
mines fine but my brothers one wont power on the fans start for a second then it shuts down then it starts again and shuts down and so on
i get a 00 on the error display but i think thats because its not got far enough to register a problem
i tried my psu in it and it did the same we are currently taking it apart bit by bit trying to find the cause.
if anyone's got any pointers that might help?
Thanks
corsair 250d case
max VI impact mobo
16gb corsair vengance 1800 ram
samsing 840 evo 256gb ssd
2x 2tb WD black drives
msi nvidia 770 graphics
h100i cooling
corsair rm 650 psu
Ratty
ok we stripped it so no mem or anything other than the mobo power connectors (h100 was still on there but all disconected) and the mobo out of the case and it seemed to post so now we are booting everytime we add something but it would go a lot faster if someone had had this happen before and we could narrow the search a bit
Thanks
NemesisChild
Level 12
Recheck all power connections, make sure that the H100 cold plate is fully seated.
And you may need to check for bent pins in the CPU socket.
My experience, it's usually a memory issue, try posting with one stick at a time or try a different set.
Intel i9 10850K@ 5.3GHz
ASUS ROG Strix Z490-E
Corsair H115i Pro XT
G.Skill TridentZ@ 3600MHz CL14 2x16GB
EVGA RTX 3090 Ti FWT3 Ultra
OS: WD Black SN850 1TB NVMe M.2
Storage: WD Blue SN550 2TB NVMe M.2
EVGA SuperNova 1200 P2
ASUS ROG Strix Helios GX601
HiVizMan
Level 40
Could you list your CPU please.
Did you swap out your working CPU and see if the issue was repeated?
