08-25-2014 01:11 PM - last edited on 03-05-2024 10:24 PM by ROGBot
08-25-2014 04:17 PM
08-25-2014 04:18 PM
08-26-2014 10:34 PM
jab383 wrote:
Depending on your motherboard model there may be a program available that doesn't involve AI Suite and gives control of more parameters than XTU. Look on your Asus driver disk, way to the bottom of the software section for Turbo V. It came with my M6 Formula, but not with an M6 Hero (still works on the Hero, though.)
If it's there, be very careful with it. There are no crutches or safety nets. One little typo is all it took to kill a very good CPU.
100% CPU usage can mean a lot of things. What it's busy doing is more important. If it's a strenuous stability test or benchmark, 70 C is pretty good. The picture shows Aida64 CPU, FPU and cache simultaneously. That's not really a strenuous test. FPU alone is the real heat producer. If that takes temperatures over 90C, you might think about better cooling if AVX-heavy floating point math is what you do with the PC. Games won't run that hot, but 3D or video rendering might.
As for the toolbar, I can only suggest uninstalling the software that puts it on the screen.
Jeff
08-25-2014 04:23 PM
08-25-2014 04:29 PM
08-26-2014 01:13 PM
08-26-2014 01:30 PM
08-26-2014 10:44 PM
