System Freeze and LED code b1
xsdefiance
HI, My system is freezing every so often while gaming or even general windows use. The motherboard error on the LED code is b1 which the manual indicates B1 Run time Set Virtual Address MAP END.
Dont know what going on with the system and how to resolve.
The system spec is here
http://www.modsrigs.com/detail.aspx?BuildID=29581
Any help would be appreciated.
11 REPLIES 11
HiVizMan
Level 40
Hello and welcome to the forum.
Do you get a BSOD error message? If yes could you try and write down the numbers that come up.
That will help us a whole heap in finding a fix.
Oh and could you please include a list of your system rather than a link to some other site. We will need that to help you. 🙂
Hi, sorry the spec is :
Motherboard - AsusRAMPAGE IV EXTREME
CPU - INTELi7-3930K
RAM - Corsair32GB
Graphics - CardEVGA3x 580 Superclocked 1536
Case - CaselabsM8
Cooling - CorsairH100
Cooling - EK GTX580 Nickel Waterblocks
Cooling - 2x EK 420 Radiators
When the system frreezez there is no BSOD just whats on screen freezes and I have to either reset or shutdown. Like I say the motherboard just shows b1
HiVizMan
Level 40
If you go into your event log what are the reasons or cause of the freeze?
http://windows.microsoft.com/en-us/windows-vista/Open-Event-Viewer
Ok there was a freeze earlier today and that is listed as a critical event. The details in XML format are :
41
2
1
63
0
0x8000000000000002
50308
System
MIN12345
0
0x0
0x0
0x0
0x0
false
0
Dont know if this helps at all ?
HiVizMan
Level 40
That just tells me your system has rebooted without cleanly shutting down first. This error could be caused if the system stopped responding, crashed, or lost power unexpectedly.
Check your PSU or swap out a your PSU and see if the problem remains.
Was there no other information in the log before this one. This error report would have been generated on your reboot.
Zka17
Level 16
Yeap, it smells PSU... What's your PSU's specs, xsdefiance?
8_Pack
Level 12
The b1 Code is during memory training mate, which means my money is with RAM problem. What is the exact part number of that 32gb Corsair RAM and how do you have it set up??? Do you have the extra floppy style EZ connector plugged into the board ??
Hi Guys, Sorry about the delay,
Ok the power Supply is OCS ZX Series 1250W
The Memory part number is corsair vengence lp model no : CML16GX3m4a1600c9
Zka17
Level 16
Well, the Vengeance series memory was not the best choice for the RIVE...
