strange power problem
prescient
just noticed something that want happening
when i turn off my pc even with shot down bottom the pc shot down then if i touch any button
on my keyboard it start again??? giving me critical error messages about shutting down improperly
and windows failed to start start after i start
spirit-crusher/ Hero 6 /i7-4770k/gtx N780OC/16GB KHX2400 /WD CB 1tb FZEX/CM storm
trooper/SAMSUNG 2333SW lcd/corsair 750 tx/water 3 extreme/win8.1 64bit pro.
4 REPLIES 4
Nate152
hello,
Windows 8-8.1 has hybrid boot enabled by default. When you shut down your pc it is actually going into sleep mode. Disable hybrid boot and see if you still have the problem.
prescient
you mean fast start up ? yes i disabled it and it worked . windows 8.1 has many power bugs like shut down restart loop .
thanks
prescient
is fast start up and hardware fast start up at bios related ? how should they be ? to initiate a real shut down . thanks
Nate152
To initiate a real shut down you have to disable hybrid boot which is a windows 8-8.1 feature. The only drawback to disabling hybrid boot is that your pc will take longer to boot as it is actually booting instead of waking from sleep mode.
