Strange GENE-V offset problem
Bluntwrapped
Hi I have been trying to use a negative offset for my 2700k overclock with no success.
LLC set to Ultra High gives around 1.58 under load. Knowing my chip needs less than 1.44v for 5ghz I input -.1 which immediately shows up in red in the BIOS. I can't boot into windows even with -.025 offset.
Sorry if this has been asked before but am I missing something? :s
56 REPLIES 56
KPRage
bugslunchbox(he he nice name.. Bear Grylls would love you! :D), see if this helps: http://rog.asus.com/forum/showthread.php?28559-Offset-mode-OC-Multiple-issues..&p=218950#post218950.. I had a few issues on offset mode which got solved by tweaking a few things..
Cheers,
KP
CPU: Intel i5 3570k OC'd to 4.6GHz @1.170V; Mobo: MVG; GPU: Zotac 1070 mini OC'd to +210MHz/+205MHz; Memory: 8GB (2X4GB dual channel) Corsair Vengeance 1333Mhz 9-10-9-T2; SSD: Samsung 840 pro; HDD: 1TB WD Green 6Gbps; PSU: Corsair GS 600w; Case: Bitfenix Merc Alpha:Hybrid Octane in progress; Cooler: Corsair H80 closed loop cooling @ high profile;
Pre & Post Build Guide
A lot of epic FAIL videos are made before one epic WIN video is made 🙂
Bluntwrapped
bugslunchbox wrote:
Yep, clearing CMOS and doing the settings again did the trick. I'm doing 4.2 Ghz @ 1.200V in full load now. I can't get the offset voltage lower becouse it crashes in idle. I'll try to see how high the CPU will go @ 1.2V. Thank you all for your help!
Great, glad to hear you got it sorted.
I wonder how HiViZMan is getting on with his testing :confused:
Seems strange if this issue applies only to specific SB cpu's.
Do you have anything to report back HiVizMan?
feniks
Level 11
pretty cool that CMOS clear fixed it. wondering why it doesn't work like that for all ...
.: R3C0NF1GUR3D :.
ASUS MVE :: 3770K bench @ 5.2GHz (delidded) :: 2x4GB Mushkin 996990 @ 2400MHz CL10 @ 1.7V :: evga 670 2GB SLI @ 1280/7108 :: Mushkin Chronos 240GB SSD RAID0 (OS) :: WD RE4 2TB (storage) 2TB :: Hitachi Deskstar 5K300 2TB (backup USB3.0) :: ASUS VG248QE 24'' 144Hz monitor
My rig with pictures
"We are what we repeatedly do. Excellence, then, is not an act, but a habit." - Aristotle
Just a note to say the new BIOS has done nothing for the problem I'm having. It's been weeks and weeks HiVizMan, do you have anything to report back yet? :confused:
Have almost given up on this.. no official answer or suggestions.
I thought one last bump wouldn't hurt though..
feniks
Level 11
Sandy Bridge are nearly EOL, I highly doubt ASUS will put an effort to fix the issue if it persists at this point ...
.: R3C0NF1GUR3D :.
