Strange GENE-V offset problem
Bluntwrapped
Hi I have been trying to use a negative offset for my 2700k overclock with no success.
LLC set to Ultra High gives around 1.58 under load. Knowing my chip needs less than 1.44v for 5ghz I input -.1 which immediately shows up in red in the BIOS. I can't boot into windows even with -.025 offset.
Sorry if this has been asked before but am I missing something? :s
56 REPLIES 56
glw165
i have always had to use a + offset myself several rigs, if using a - offset must be because of failed oc and not cleared bios which is showing a high vcore still, i keep llc down lil lower for heat issues and make it up in vcore, just my 2 cents worth !
[SIGPIC][/SIGPIC]
Coolermaster Cm Storm Stryker,
I7 3770k Delidded @ 4.8,
Asus Z77 Maximus V Etreme,
Corsair Vengeance 16gb (2133),
Evga gtx Titan,
Ssd,
Corsair Ax 1200 Psu!!!
feniks
Level 11
I have read about this issue with SB chips on Maximus V boards, OP is not the first one having same problem (0 offset overshooting greatly and negative ones don't work at all) ... I believe ASUS have quite a few things to fix in their BIOSes ... glad that Shamino is back, maybe there will be salvation for all the problems in next BIOS revision, I really do hope so, because I'm tired of Clearing CMOS to get things stable ...
.: R3C0NF1GUR3D :.
ASUS MVE :: 3770K bench @ 5.2GHz (delidded) :: 2x4GB Mushkin 996990 @ 2400MHz CL10 @ 1.7V :: evga 670 2GB SLI @ 1280/7108 :: Mushkin Chronos 240GB SSD RAID0 (OS) :: WD RE4 2TB (storage) 2TB :: Hitachi Deskstar 5K300 2TB (backup USB3.0) :: ASUS VG248QE 24'' 144Hz monitor
My rig with pictures
"We are what we repeatedly do. Excellence, then, is not an act, but a habit." - Aristotle
Fingers-Crossed!!!!
ASUS Maximus IX APEX || Core i7 7700K || Corsair H150i Pro || EVGA RTX 2080 Ti B.E. || G.Skill Trident Z RGB F4-3000C15D-16GTZR 16GB (2x8GB) DDR4 @ 15-16-16-35-2N || ADATA SX8200 Pro 1TB x 2 (RAID0) || WD RED 3TB x 2 || Corsair AX1200i || NZXT H700i (without the smart hub) || Dell U3011 || Windows 10 Pro x64 || Logitech Z2300 THX Certified 2.1 & Corsair Vengeance 2000 ||
Thanks for adding to the thread guys. I'm no further forward.
Stuck with using static voltages. 4.8Ghz @ 1.370v
I wish I had known about this before buying the board. It's useful having the extra 6gb/s ports but I probably would have bought another GENE-Z GEN3 instead.
I can take CoreTemp and CPU-Z screenshots if it'll help, but since I can't make even the smallest incremental change with a - offset I think the problem is BIOS related.
HiVizMan
Level 40
Confirm which bios you are using now please and I will try and duplicate with some SB processors. And explain again why you feel - offset is needed for your overclock?
I'm using 1408 now as you suggested. 1604 has the same issue.
LLC auto and offset auto gives me massive voltage in Windows (1.58v+)
Changing LLC makes very little difference to load voltage, with medium LLC (Auto offset) I'm sitting around 1.56v.
I know my chip needs 1.368v for 4.8Ghz, so the offset needs adjusting with a negative value.
HiVizMan
Level 40
Cheers mate thanks for the recap.
Will pull out some boards and SB processors and see if I duplicate.
Great, thanks for this 🙂
Bluntwrapped
Have you had a chance to try this yet HiVizMan? Just wondering how you got on.
HiVizMan
Level 40
I have it planned for the weekend my friend. As soon as I have some results I will post up here.
