SSD comparability Striker Extreme HELP
DarkStalker980x
Hi all, not sure if this is the right place to post but it is in fact a ROG board 😉 So for the time being, here goes...
My problem is I bought 2x 128GB Kingston SSDNow V100+ SSD (because cheap!) to use as a RAID0 OS disk on an old ASUS Striker Extreme LGA775 nForce 680i mobo but with it all components connected, the BIOS does not recognize these SSD's no matter what BIOS configuration I try to get the BIOS to detect the SSD's in. Using one SSD connected to SATA port 1 or 2 or 3 and so on yet still no detection and swapping around the BIOS SATA and IDE settings, I cant think of anything else.
SSD RAID0 does work on these Motherboards as I've read countless times on forums so I think its a problem with the SSD's, they even come with their own external enclosures to use as USB external storage yet they will not show up in Windows 7!
Motherboard BIOS firmware is '2002' which is the latest available through ASUS website.
This could be a problem with the SSD'S as there is firmware available for these SSD's which could help but the firmware update procedure requires burning the firmware image to disc, booting from the disc and updating the SSD that way BUT as the BIOS/POST does not detect the SSD, the firmware updater does not detect the SSD either, Kingston states in order to update the SSD you must use IDE BIOS settings and disable SATA ... Doing this does not detect the SSD either.
According to Kingston, the SSD firmware update is a MUST because these SSD'S have been known to fail a lot of the time and the update has the fix...
Maybe a third party Motherboard BIOS firmware might help ... Or actually updating the SSD's through a more modern PC.
This is my personal system for now (lol) so any help is much appreciated! Thanks.
CPU Q8300 3Ghz
Asus Striker Extreme 2002
2x 128GB Kingston SSDNow V100+ RAID0
Nvidia GTX 480
4GB 1333Mhz Corsair RAM
880W PSU
Win 7 64bit
CoolerMaster HAF-X
Intel i7 980x OC
Corsair H100 CPU Liquid Cooler
Gigabyte G1 Assassin
Enermax MaxRevo 1500w PSU
Corsair Dominator GT 3x2GB 1866Mhz
Corsair Vertex 3 MAX IOPS 2X240GB Raid0 SSD
POV/TGT GTX590 Ultra Charged QUAD SLI
Creative Sound Blaster X-FI 20K2
Bluray Drive
Windows 7 Ultimate 64-Bit
Acer G24 1920x1200
Razer Keyboard & Mouse
Logitech Z-5500
4 REPLIES 4
DarkStalker980x
Heading should say COMPATIBILITY ... Blames Google Chrome 😛
CoolerMaster HAF-X
Intel i7 980x OC
Bluray Drive
Acer G24 1920x1200
Logitech Z-5500
desolator4u
My Crucial M4 works perfectly fine. If yours doesn't show up in the BIOS and works fine another board, then upgrading their firmware seems like the only option at this point.
8700K / Noctua U12S / Maximus X Hero / 2x8GB Corsair Vengeance 3200MHz / EVGA GTX 1080 Ti / Seasonic Prime 650W / 4 x 1TB SSD / 970 Pro 512GB M.2 / Game Zero Headset / K95 Platinum / Logitech G502 / Win 10 x64/ ViewSonic XG2701 1080p 144Hz
Retired
Not applicable
Hi..
I am at a P5E3 deluxe ddr3 (775) Q6600
And i tried installing a SSD, but it was not stable. so i installed a Raptor instead, for OS disc..
I am not fully at home, when it comes to these vintage boards, and pch prob isnt the same as the striker..
These vintage boards are really nice, for everyday use..
HiVizMan
Level 40
You will need to set the bios SATA mode to AHCI to install your OS. Also know that you will not get the full speed of your SSD if you have one that is a 6G due to the SATA ports on that board not being 6G.
