06-28-2012 05:12 AM - last edited 3 weeks ago by ROGBot
06-28-2012 05:54 AM
Zka17 wrote:
Welcome to the ROG forum!
Could you, please, double check the APM settings in the BIOS? (section 3.5.7 in the manual)
06-28-2012 06:24 AM
Zka17 wrote:
OK, good. Then, could you double check your front panel connections, please? With special attention to the power and reset buttons?
06-28-2012 07:10 AM
08-16-2012 02:20 PM
08-16-2012 08:36 PM
chevas wrote:
I'm using a PZ77-V Deluxe board and I am experiencing the same symptoms.
I was not getting the 03 Q-Code until I updated the bios, but after updating the bios to 1504, it does display the same Q-Code when I attempt to shut down, either from Windows or simply by trying to power off.
I tried going through the steps you outlined: shutting off PSU, unplugging all non-essential drives, clearing CMOS, then trying again, but I still can't shut down.
The CPU Error light also appears after I attempt to shut down or power off. THe only way I can turn the machine off is to turn off the PSU.
10-12-2015 09:58 PM
