Sabertooth Z87 Digi+ Power Control
Flegma
Hello
Sabertooth Z87 is great motherboard but "Digi+ Power Control" in AI Suite is still mystery for me. So, what are benefits of using this settings if I'm not overclocker?
For example what will happen if I boost "CPU Load Line calibration"' from default Level 1 to Level 3 or more? Or CPU Current Capability and CPU Power Phase Control?
In other words. Will I have more responsive system if I "mess" with these settings if I'm on stock 4670K with turbo enabled.
Thanks
i5 4670K (no OC) on Sabertooth Z87, Asus GTX760 DC2OC, Corsair Vengeance 8GB @XMP 1600, Cooler Master M2 720W - Noctua NH-U12S CPU cooler
WD Blue 1TB (EZEX), WD Green 2TB (EARX)
Nate152
Hello Flegma
If you are not overclocking you don't need to fool with any of the settings. if you are looking for more performance you will get it by overclocking your cpu. You have the 4670k which is a good overclocker and your noctua cooler is one of if not the best air cooler.
Have a look at this, this will tell what the settings are for.
http://rog.asus.com/242142013/labels/rog-exclusive/maximus-vi-series-uefi-guide-for-overclocking/
