09-11-2012 02:16 AM - last edited on 03-06-2024 07:24 PM by ROGBot
09-11-2012 02:26 AM
09-11-2012 03:32 AM
Bundy_Drop_Bear wrote:
*50W is all you should need even with the specs you posted 1000w is overkill.
09-11-2012 03:42 AM
09-11-2012 04:10 AM
HiVizMan wrote:
Are you using a HDMI cable to a TV?
Please list the cable type, connection and where, plus your monitor used.
09-11-2012 04:23 AM
09-11-2012 04:41 AM
HiVizMan156548 wrote:
Nope I need to know your VGA cables please. There are a number of instances where the BIOS screen will not be presented if the native resolution of the monitor used is not compliant, and cables also impact on the output. So just let me know what type of VGA cable you are using please.
09-11-2012 11:39 AM
09-11-2012 01:00 PM
09-11-2012 11:37 PM
HiVizMan wrote:
Thank you the information is brilliant. If at all possible are you able to use another cable, one that does not need an adaptor. I am still focusing on the issue of no BIOS screen being visible. Has this been resolved yet.
If you are able to enter BIOS I would suggest you flash your BIOS to the latest three series BIOS for your board.
Cheers
