RIVE realtek hd audio no split streams?
Emerald_Lotus
:confused:
ok so on my old mobo i can assign in realtek audio manager for it to seperate what output devices play back what audio stream. go to top right hand corner of the manager click "Device advanced settings" brings up a box with two seperate options for playback device and one for recording device. the one for the RIVE only has recording device. the option im looking for is under Playback device -> Make front and rear output devices playback two different audio streams simultaneously. any body know whats up ?
i want to multi stream on the built in audio card. like have game sound go thro back jack and vent go thro the front jack to headphones. as it sits now they are both sharing the same stream realtek manager puts them both under the speaker output so i get one or the other.
Cooler Master CM Storm Trooper
Intel 3930k @ Stock
16gig Mushkin Redline@ 1866
Corsair pro series Gold ATX1200w
Sapphire Radeon HD 7850 x 2 CrossfireX
Patriot Pyro SSD 120gig
Western Digital Black 1Tb
(will update the rest of the specs when i get the rest of the stuph :)>
7 REPLIES 7
TechRaven
Emerald Lotus wrote:
:confused:
Waking the dead here, but...
Ugh in the exact same situation, it looks like the setting is no longer there in Realtek HD Audio Manager...
Anyone ever figure this out?
Hi, I'm newb here, and as this is the first week I can use my system I'm still encountering some problems , most of them minor. I put my video on 3.0, installed my system with RAID enabled
I am encountering the same problem as mentioned above No seperate audio streams through front and back . I normally have my daughter (2.5yrs old now) watch a (childrens) television show (via youtube or direct from disc) while I'm gaming before she does her midday sleep , but to be honest I do not like it to much if her children's program has machine gun fire and blood & gore sounds in it constantly. (Yes, I do shield her from the screen im playing on...)
My 2 older computers do not have this problem & are both based on Realtek AC97 or HD sets.
Even though I can route her sound to a screen using the HDMI interface, it isn't the sam quality as my (simple) 2+1 audio set.
I did notice my "front L+R" 3.5mm Jack is bound to speakers (as are L&R, RL&RR, SubW, sides jacks) instead of a seperate headphones...
So I would need my front L+R jack removed from the speakers placed under a new header (front output) and the possibilty to associate things with it. Normally this is a standard part of the audiomanagers functionality but I only see the input jacks which can be spearted not the output jacks.
Even though I have quite some experience with setting up stuff this is a bridge to far for me. generally speakling I want my headphones for TS3 & games, and my speaker set for youtube and as such as master (most plug ins do not allow you to choose output channel...)
Could I help this by downloading a realtek audiomanager from Realtek instead of ASUS? Would It solve this problem? I prefer not to buy a seperate audiocard if this realtek has the functionality as well. I'm 38 yrs old so my ears do not differentiate between a nice external card or the main anyhow.
Hope someone will read this.
I have a thermaltake a71 chaser case, and guess what: a RIVE mainboard (3930K, 32Gb, 2*780GTX,256Gb SSD,250Gb veociraptor and 2* WD1Tb (r)aid0 set with Windows 7 Ultimate.)
(edit: fixed typo(s))
I fixed this for myself but not using the Realtek audio.
I set up my HDMI card to provide audio to my screen which has a plug for headphones, I use it for my speakers now (2+1, so only 1 green plug) . Could use it for the headset, but I use a mic as well, no pink slot to be found) really doesnt matter to much. This gives me a second stream and so I can use my headset (front plugs green&pink) and the speakers: HDMI: screen speaker plug =>through NVIDIA GTX audio
For now this solves my problem.
dchhui
I don't know if you guys have solved this issue yet but the latest Realtek drivers on the Asus website do have an option to split the front and rear audio ports now.
TechRaven
dchhui, confirmed in windows 8 atleast.
The drivers are listed for Windows 8 but not Windows 7, although the contents seem like there would be support for both, but am not sure. Did you use windows 7 or 8? I've been contemplating going back to 7, would hate to have this revert back to the non-split again.
Is this for any "serious" audio work, or just gaming?
If the former, as an audio engineer myself, I highly (and I mean highly) recommend getting a discrete audio card; the difference is profound when going from even the best onboard audio to an "average" discrete card, and from the ALC898 to either (my person favorite) the Creative Titanium HD or Asus Xonar Essence STX, it's a whole different world.
The reaosn I favor the TiHD to the STX is that the former uses CMSS3D, which is binaural audio for virtualized "surround" sound; that means that the audio can be "set" to be coming from anywhere in a 360 degree radius, as well as at any elevation from 0 to 90 degrees above you. There can be up to 128 different, completely unique directional "voices" at once!
With the STX, instead of CMSS3D, you have Dolby Headphone. While there's nothing inherently wrong with this, the way it goes about making "surround" audio is different. Instead of virtualizing sounds to any point in space, it actually virtually mimics a 5.1 or 7.1 SPEAKER configuration, so everything sounds like it's coming from 6-8 discrete speakers, instead of being truly directional.
That said, for film use, the STX is a tiny bit better, while for gaming and recording the Ti HD has proven itself superior to me, using everything from $20 headphones to my Grado PS1000's and GS1000's, or misc un-named speakers to Sonus Faber Cremona Auditor custom editions, the sound card has never been a "bottleneck" to me. This is for both listening to, and recording, music, as well as editing and mastering records (24-bit/192khz originals for the extra bit depth while editing).
If you have a decent pair of headphones or speakers, a dedicated card is truly worthwhile!
TechRaven wrote:
dchhui, confirmed in windows 8 at least.
I have struggled with this problem a long time. Just tried the Win8 drivers on my win7 pc and I can confirm they work. You now have the option to split the audio streams (Multi-Streaming).
Maybe you already figured this out but then someone else may find this info useful.....
