RC Bluetooth Problem (M4E)
helrich
Just installed the board in my system, and everything is working fine except for RC Bluetooth.
Regular ROG Connect works with my laptop plugging into the port. Bluetooth also works, when not in RC mode, and I'm able to pair and connect my Droid X2 and transfer files, etc. But when I hit the bluetooth button on the back of my system, I can't connect with RC Bluetooth! I open the app, go to Devices, and select "RC Bluetooth" and it cranks for a second or two and says "The connection is not available."
Using the latest Toshiba bluetooth driver, latest mobilink driver (and I make sure it is running in my task manager), latest RC Bluetooth on my Droid (Android 2.3.4). Done multiple installs of all the above, even removed the RC Bluetooth I got from the Android market and tried installing from the zip on the Asus support site.
I'm not terribly worried about getting to work, I mean I do have ROG Connect working on the laptop (not GPU Tweak though, but thats a different story), but would like to give the RC Bluetooth a go!
Tried searching for answers and came across a walkthrough from Brian@Asus, but that hasn't helped.
Thanks guys!
Oh, almost forgot, using BIOS 2105, and all the latest drivers for chipset, etc etc.
KILLER_K
Don't worry about it. As you're not alone. Mine does the same exact thing. And everyone else I have talked to yields the same problem. Seems either they need to update the android app. Or maybe a windows update caused the issue. Mayne even a bios update did it. Thanks
