Rampage iv extreme x79 code 00 big problem
Marceleos
HI GUYS I HAVE A BIG PROBLEM THAT I CANT SOLVE TWO DAYS AGO I BOUGHT RAMPAGE IV EXTREME X79 + I7 4930K
AND I RUN IT BUT IT DOESNT POST THE CODE LED 00
http://event.asus.com/2012/mb/usb_bios_flashback_guide/
I DID EVERYTHING IN THIS PAGE SUCCESSFUL UPDATE BIOS .ROM ONLY BIOS .CAP THIS THE MOTHERBOARD CANT READ IT
LED JUST FLASH FOUR TIMES THEN IT STOPS AND THERE IS NOTHING ON THE SCREEN ONLY BLACK SCREEN
NOW MOTHERBOARD VERSION BIOS 1202
I THINK THIS CPU Incompatible HOW CAN I DEAL WITH THIS HUGE PROBLEM
16 REPLIES 16
Chino
Level 15
Welcome to the ROG forums, Marceleos.
Please locate that long and thin sticker that has a barcode and a ton of numbers on it. Please post the last 4 digits for me.
1202 is what the OP says is the bios.
1202
HiVizMan
Level 40
You need to take the board to someone who has a SB-E processor and have them flash the bios for you. Your board needs the CAP converter to be run first before you can flash to the new bios.
Or you can buy from Ebay a BIOS chip with the new bios flashed and fit it to your motherboard your self.
Or you can take the board to a PC store and ask them to flash for you.
There is no other way.
Mafste
Listen to HiVizMan Marceleos.
Those 2 ways are the ONLY way.
1. Order a new bios from Ebay preflashed with the latest bios.
or
2. Get your computer to a computerstore and ask them to flash the bios on your motherboard because your CPU is too new and won't boot yet.
After the bios has been flashed your Rampage will accept the 4930k and run perfectly!
I want to buy the chip from this link
http://www.ebay.com/itm/New-Bios-Chip-Asus-Rampage-IV-Extreme-/170972556815#vi-content
i will ask the buyer to programmed it at bios version 4701
do you think the motherboard will work after installing this chip
Chino
Level 15
Chino wrote:
As long as the BIOS is 4310 or newer, it will support the i7-4930k.
BIOS now 1202 i want to program the chip to latest version of the bios 4701 i think it will support the cpu and it will work
Update 🙂
Finally do not work And CPU RED What does it mean
