Rampage IV Extreme Voltage Problem +3,3V +5V +12V VCore
aznsteil
Hey guys,
got a problem with the voltage, hope you guys can help me:
HiVizMan
Level 40
I would suggest your voltage is fine, but that you have a problem with the AISuite
I would uninstall it use the link in my sig to completely remove the application and use HWmonitor to determine if your system has any issues with voltage.
Raja
Or uninstall whatever else you are running with AI Suite causing the issue.
