Rampage IV Extreme - Power on by Keyboard or Mouse?
Doc_Scorpion
Hey fellas,
as the topic says: Is there a way to start the computer by Keyboard or Mouse?
My keyboard as well as my mouse are USB connected.
Thanks in advance for hints.
Doc
HalloweenWeed
Level 12
I assume your Keyboard has a "power" button? If not then no. And it will work W/PS2 keyboard but IDK about USB. Try these settings:
Advanced menu.
USB configuration submenu:
Legacy USB support: Disabled
Legacy USB3.0 support: Disabled
APM submenu:
Power on by PS/2 kybd: enabled
Power on by PS/2 mouse: enabled
The problem is once you Disable "Legacy USB support" you may not be able to get back into the BIOS again without a PS2 keyboard or CMOS reset. The alternative is copy BIOS1 -> BIOS2 before setting this, then if you need to get back into BIOS switch to BIOS2. FYI. GL.
i7-3930K; Asus RIVE; G.SKILL Ripjaws Z 4x4GB DDR3 1866; MSI 7870 2GD5/OC; Crucial M4 SSD 256GB;
Corsair 1000HX; Corsair H100, 4x Excalibur 120mm PWM CPU Fan p-p, AS5; SB X-Fi Titanium Fata1ity Pro;
Dell U2412m IPS 1920x1200; Cooler Master HAF 932 case; Tripp-Lite OMNIVS1500 UPS fully Line-interactive.
(EVGA site: ) And I have a second (wife's) computer, Eve.
Overclocking is useless to me if it is not rock stable.
Cheers m8, thanks for the advice 🙂
