11-02-2016
12:43 PM
- last edited on
03-06-2024
09:05 PM
by
ROGBot
11-02-2016 02:02 PM
11-02-2016 03:05 PM
MeanMachine wrote:
Hi Brio Bane 🙂
Qcode OC is undocumented and reserved as far as I know however, Qcode 14 is pre-memory CPU initialization.
As your DRAM_LED is on constantly it could be your DIMMs. Post will not advance till this is rectified and you will not be able to access Bios.
Try clearing CMOS and startup with just one DIMM in the first slot to test and see if your DIMMs are working. Try also switching them around in case one is failing.
Also make sure the modules are seated well and clipped in properly.
This error can also mean your CPU has issues and would require a check of the CPU socket for bent pins.
11-02-2016 11:52 PM
11-03-2016 10:47 AM
MeanMachine wrote:
Has this just started to happen Brio Bane.? Or have you installed new RAM. Also did you try different DIMM slots.
The QVL list for your MB does not list your DIMMs but that maybe because it has not been updated since 25/6/2014. Neither is your MB listed on the GSkill QVL.
If they have been working before then the MB is suspect. If they are new then they may or maynot work properly with your CPU.
If you have your MB out of the case in benchtest mode then its best to resolve the issue before re-assy.
What version Bios are you on.? Version 4901 is the latest for system stability and worth a try.
11-03-2016 07:44 PM
11-04-2016 09:43 AM
03-31-2018 07:21 AM
Brio Bane wrote:
I've been looking around, but I haven't found anything that fits quite what I'm looking for. So here is the situation.
I went to turn on my PC yesterday. Lights come on, fans start spinning. I sit back in my chair, then the computer shuts off. I stand up to look at it and then it powers back up. It repeated this a few times. After trying a few things it no longer shuts off and restarts.
I press the power button. The lights come on. The Fans start. The board shows code "14" for a few seconds, then goes to "0C" and stays there. The Dram LED light is also on (constant, not blinking)...I can't get into the bios.
System Specs:
Motherboard: Rampage IV Extreme
CPU: I7-3930k
Cooler: NZXT Kraken X60
RAM: Gskill Trident X ( 32g- 1600)
GPU: GTX 770 4g
PSU: EVGA Supernova Nex1500 Classified
This is my first time posting on a forum, so if there is anything else I need to include just let me know.
03-31-2018 10:06 AM
