10-20-2012
10:49 AM
- last edited on
03-06-2024
06:30 PM
by
ROGBot
10-20-2012 11:28 AM
10-20-2012 11:33 AM
10-20-2012 02:43 PM
HiVizMan wrote:
I would suggest you start your build from scratch. Your system will not read a false temperature in BIOS that is out by that much.
I personally think your cooler was a) not working, b) not fitted correctly.
Just hope that you do not have a toasted CPU. Do you have any idea what kind of voltage was set when you booted that first time?
10-20-2012 12:51 PM
10-21-2012 03:04 AM
11-22-2012 05:37 PM
11-23-2012 12:59 AM
futiless wrote:
Seems like everywhere I looked that ASUS dumped the Xeon 8 core support back in July / August... I can't get anymore than '00' ever since they upgraded to the .CAP !!!!
Sorry look like our 8 cores are now end of life... AHHHHHHhhhh
SEan
11-24-2012 08:36 PM
SEan
HiVizMan wrote:
Well you can flash back or revert to a earlier non CAP bios if you want. There are two ways of doing that. The first is the rename and USB flash back method. See my sig for the renaming protocol. And the others is to get a new BIOS chip flashed to the BIOS of your choice from either Ebay or maybe from ASUS.
11-25-2012 02:12 AM
