Rampage IV Black Edition - Not starting QCod 19 and 14 then power off.
micltan
Hi Everyone.
I recently built a computer with these specs.
RAMPAGE 4 BE (serial ends with 0603)
i7 4960x
Corsair 2133 Dominator 32gb
Corsair H100i CPU water cooler.
ASUS 780 Stix 6gb GPU
It was working perfectly, then I decided to install an extra fan in my case which also has LEDs
I plugged the fan power into FAN2 which worked fine.
Stupidly, I then plugged the on/off for the fan LEDS into TEMP2, bad idea!
Here is a picture of the connections for your reference.
39381
The computer started then shutdown almost immediately.
Now when I hit the power button it powers up for a about a second, the error code goes from 19 to 14 then shutsdown.
I'm worried I fried my mobo.
Searching the internet, this seems like a similar problem, should I try doing these steps
http://www.tomshardware.co.uk/answers/id-1993676/asus-rampage-black-boot.html
If anyone can help me, I would be so happy.
Cheers
MT
micltan
More specs after reading the template post 🙂
Motherboard model: Rampage 4 black edition
UEFI Version: Not sure
CPU: 4960X
Memory kit part number (s) and amount in GB: Corsair Dominance 4 x 8gb (32gb)
GPU: ASUS GTX780 OC STRIX 6gb
SSD/HDDs/Optical drives:
LG BLU RAY BURNER
SAMSUNG EVO 840 250gb
2 X WD BLACK 2TB
PSU: CORSAIR AX860i
USB Devices (model/version number):
Monitor: DELL 27inch
CPU Cooler: Corsair H100i
PC CASE: CoolerMaster HAV XB
Operating system: Windows 8.1
System Overclocked (provide details)? NOT OC
