Hello!
I have got a Rampage iii extreme with a GTX 480.
Im using the 3rd pcie slot.
The the graphic card is too big and i need to use the 2nd PCIe. I read that the all pci are 16x.
I did move it up but it would not display.
I turned on only the PCIe #2 which has the graphic card, all others (#1,3,4) are in off position.
i tested the 2nd pcie with a gt520 and the display looks fine.
I add and image that u can see why need to change the card slot.
any idea? thanks!!!
