Hi all
Ive got a coolermaster 800w silent pro gold, with 3 hardwired cables. The 24 pin is obvious, but there's also a cable split into 2x4 pin plugs labelled in the manual as cpu and another 8 pin labelled as pcie.
The 8 pin socket at the top of the MB has half blanked off, so do I just plug the 2x4 pin plugs into the two 4 pin sockets or remove the blanking plate and use one of the 4 pin plugs and the 8 pin plug? The manual is pretty unclear on this point.
I dont actually need the 8 pin for anything, its redundant if not used here.
Any help appreciated, I haven't built a pc for a few years 🙂
