R4E strange problems, you know help me?
sisco
Hi
I have a strange problem with my R4E:
Profile X.M.P. completely automatic except for the following values:
Manual
By all core
CPU ratio 47
VCORE 1.4 bios
LLC ultra high
CPUcurrent capability140%
VCCSA current capability100%
CPUpll VOLTAGE 1.8
VTT DRR ab / cd VOLTAGE 0.82500
Now to the problem, which occurred 2 times after upgrading to bios 1004 and 1 after 1005.
Launching a mkv with TMT5, PC is turned off and on, back in wuindows 7, raising the same file is turned off and on again, re-raised all went well. (Bios1004 2 days ago)
Today I noticed that windows was asking me to update the WEI, launch the utility and after a few seconds and the PC is switched off and back on again. (Bios1005).
The way in which the problem occurred, it seems as if he went into protection when it exceeds the allowable current threshold, for example, without setting the CPUcurrentcapability over 100% by OC
By starting DIGI + powercontrol, I noticed that the bios was set to automatically VCCSA LLC on extreme, leaving the VCCSAcurrent capability100%, so now I have brought to 120%, but I do not know if it can be to the cause.
I insist that while updating the BIOS to version 1004, I installed nvidia drivers for my gtx580 290.53beta
Another strange thing that occurred today, after having mounted my new Koolance MB-WB ASR4E, when I reconnected the pc, does not turn on the power button (even on the MB), I made a CCMOS, but to no avail , is ignited with the reset button on the MB, I entered the bios, I set the parameters listed above, save and reset, but when you restart the debug LEDs crashed to the value 61 (NVRAM initializzation), turn off and turn on the PC, debug LEDs is stuck on 00 (NOT USED). CCMOS, enter bios setup, imposed as above save and reset the computer starts normally.
This problem happened before the sudden shut down with bios 1005.
Does anyone have any idea what might have happened?
10 REPLIES 10
LiveOrDie wrote:
Switch back to the older bios then or just switch to your 2nd bios which probably is a older version dont fix what not broken :).
Since I brought the 120% VCCSA CurrentCapability, the problem is not verified, in fact I think that was the cause, which I do not understand however, is the other problem (Another strange thing that occurred today, after having mounted my new Koolance MB-WB ASR4E, when I reconnected the pc, does not turn on the power button (even on the MB), I made a CCMOS, but to no avail , is ignited with the reset button on the MB, I entered the bios, I set the parameters listed above, save and reset, but when you restart the debug LEDs crashed to the value 61 (NVRAM initializzation), turn off and turn on the PC, debug LEDs is stuck on 00 (NOT USED). CCMOS, enter bios setup, imposed as above save and reset the computer starts normally.),which surely experts like Raja or Shamino will give a theoretical explanation, given the isolated nature of the same.
