12-23-2011
04:24 PM
- last edited on
03-05-2024
07:29 PM
by
ROGBot
12-23-2011 05:37 PM
12-23-2011 07:42 PM
HalloweenWeed wrote:
Your VRM is overheating. Shutdown is to protect the components from damage.
A. Don't go over "High" LLC. "Medium" is recommended.
B. Don't raise Vcore that high.
C. Use variable Vcore +0.010V.
D. Increase VCCSA to 1.25V or more (1.3) if needed.
E. You might need to increase CPU PLL to 2.0 (only try if needed).
GL.
12-23-2011 08:18 PM
12-23-2011 09:30 PM
In your situation only, I recommend:
Extreme Tweaker menu:
EPU power saving mode: Disabled
Digi+ power control submenu:
CPU load-line calibration: Medium
CPU current capability: 130%
VRM over temperature protection: Auto
CPU power duty control: T.Probe
Vcore MOS volt. control: 7V
CPU power phase control: Extreme if non-selectable, otherwise Optimized
CPU spread spectrum: Disabled
VCCSA load-line calibration: Auto
VCCSA current capability: 120%
VCCSA fixed freq: 300 (default)
CPU VCCSA boot up voltage: Auto
CPU VTT switching freq: Auto
DRAM-AB current capability: 120%
DRAM-AB power phase control: Optimized
DRAM-CD current capability: 120%
DRAM-CD power phase control: Optimized
CPU Performance settings submenu:
Turbo mode parameters submenu; Power limit control: Auto
Advanced menu.
CPU configuration submenu:
Intel Adaptive thermal monitor: Disabled
Monitor menu:
Anti surge support: Disabled
12-24-2011 06:22 AM
12-24-2011 08:05 AM
mdzcpa wrote:
What are your symtons now? Are you getting shutdowns, blue screens, or errors?
What RAM are you using, what speed?
HW is right, do not over adjust LLC. Most guys can get up to 5Ghz overclock on Medium.
Higher VTT/VCCSA is normal on these boards. You need it for higher RAM frequency or tighter ram timings.
12-24-2011 10:40 AM
12-24-2011 11:47 AM
LiveOrDie wrote:
Only some 3930K's can get pasted 4.6Ghz only if you get a chip that good quality so don't be shocked if you hit a wall, raja using a 3960x chip which can reach higher clocks.
