R4E pch fan doesn't turn
walter
Hi, someone have a solution ?
On my R4E ( sli mode) pcm Fan doesn't turn.
I've tried to set all options also disable pwm fan controll but nothing.
pch temp is 43°C.
Walter
Raja
PCH not hot enough I suspect. 43C is a good operating temp.
HiVizMan
Level 40
Does the fan turn over when you power on to POST?
no the fan is off
