R4E - All slots running at 1/2 speed
MMFC378
Need a little help guys.
All my slots are running at half speed. x16 only runs at x8 and x8 runs at x4. Ive moved my 1080 to every slot and its the same result. Forcing Gen 3 also cripples my system for some reason. Major stuttering in windows 10. So i only get Gen 2 x8. Its set to Gen 3 in the bios and I flipped the dipswitch for every slot i used and same result.
3930k
RIVE Bios 4901
16GB G Skill 17000 CL11
GTX 1080 FE
EVGA 1000W
I removed the CPU and checked the pins, everything looks good. CPU contacts looked clean as well. It also hates restarting from the bios. It hangs on random debug codes like 16, 0C, 62,64,92,67. It seems to hang just before it would initialize the gpu.
62- Installation of the PCH Runtime Services
64- CPU DXE initialization is started
92- PCI Bus initialization is started <---seems to be a big one, but this one doesnt show every time
94- PCI Bus Enumeration
Again, these are just a few of the numbers i remember and only seem to occur when it restarts from the bios.
Heres a little from cpuid
Processors Information
Socket 1 ID = 0
Number of cores 6 (max 6)
Number of threads 12 (max 12)
Name Intel Core i7 3930K
Codename Sandy Bridge-E
Specification Intel(R) Core(TM) i7-3930K CPU @ 3.20GHz
Package (platform ID) Socket 2011 LGA (0x2)
CPUID 6.D.7
Extended CPUID 6.2D
Core Stepping C2
Technology 32 nm
TDP Limit 130.0 Watts
Tjmax 91.0 °C
Core Speed 4199.0 MHz
Multiplier x Bus Speed 42.0 x 100.0 MHz
Rated Bus speed 3199.3 MHz
Stock frequency 3200 MHz
Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T, VT-x, AES, AVX
L1 Data cache 6 x 32 KBytes, 8-way set associative, 64-byte line size
L1 Instruction cache 6 x 32 KBytes, 8-way set associative, 64-byte line size
L2 cache 6 x 256 KBytes, 8-way set associative, 64-byte line size
L3 cache 12 MBytes, 16-way set associative, 64-byte line size
Max CPUID level 0000000Dh
Max CPUID ext. level 80000008h
Cache descriptor Level 1, D, 32 KB, 2 thread(s)
Cache descriptor Level 1, I, 32 KB, 2 thread(s)
Cache descriptor Level 2, U, 256 KB, 2 thread(s)
Cache descriptor Level 3, U, 12 MB, 32 thread(s)
FID/VID Control yes
Turbo Mode supported, enabled
Max non-turbo ratio 32x
Max turbo ratio 57x
Max efficiency ratio 12x
Min Power 53 Watts
O/C bins unlimited
Ratio 1 core 57x
Ratio 2 cores 57x
Ratio 3 cores 57x
Ratio 4 cores 57x
Ratio 5 cores 57x
Ratio 6 cores 57x
Ratio 7 cores 35x
Ratio 8 cores 35x
Temperature 0 42 degC (107 degF) (Package)
Temperature 1 37 degC (98 degF) (Core #0)
Temperature 2 43 degC (109 degF) (Core #1)
Temperature 3 34 degC (93 degF) (Core #2)
Temperature 4 36 degC (96 degF) (Core #3)
Temperature 5 32 degC (89 degF) (Core #4)
Temperature 6 38 degC (100 degF) (Core #5)
Voltage 0 1.36 Volts (VID)
Power 00 90.98 W (Package)
Power 01 73.95 W (IA Cores)
Power 02 17.03 W (Uncore)
Clock Speed 0 4199.02 MHz (Core #0)
Clock Speed 1 4199.02 MHz (Core #1)
Clock Speed 2 4199.02 MHz (Core #2)
Clock Speed 3 4199.02 MHz (Core #3)
Clock Speed 4 4199.02 MHz (Core #4)
Clock Speed 5 4199.02 MHz (Core #5)
Core 0 max ratio 57.0 (effective 42.0)
Core 1 max ratio 57.0 (effective 42.0)
Core 2 max ratio 57.0 (effective 42.0)
Core 3 max ratio 57.0 (effective 42.0)
Core 4 max ratio 57.0 (effective 42.0)
Core 5 max ratio 57.0 (effective 42.0)
Chipset
Northbridge Intel Sandy Bridge-E rev. 07
Southbridge Intel X79 rev. 05
Graphic Interface PCI-Express
PCI-E Link Width x8
PCI-E Max Link Width x16
Memory Type DDR3
Memory Size 16 GBytes
Channels Quad
Memory Frequency 1066.5 MHz (1:16)
CAS# latency (CL) 11.0
RAS# to CAS# delay (tRCD) 11
RAS# Precharge (tRP) 11
Cycle Time (tRAS) 30
Row Refresh Cycle Time (tRFC) 160
Command Rate (CR) 2T
Host Bridge 0x3C00
If you need more info, please let me know. Any help would be greatly appreciated. Thanks
0 REPLIES 0
