11-09-2011 02:14 PM - last edited on 03-05-2024 07:43 PM by ROGBot
11-09-2011 02:58 PM
11-09-2011 04:03 PM
11-09-2011 05:25 PM
11-09-2011 05:37 PM
11-09-2011 06:01 PM
11-11-2011 03:37 AM
11-14-2011 08:20 PM
zagman wrote:
Thank you for your relies. I have two PSUs (bridged, effectively working as one) one is corsair 650W and the other is enermax 750W, i do not believe that i have power related issues. I will try to fiddle more with the rams in bios and disable every tweak i can find. I had to do a little work on my computer and it was just going extremely slow. Now i found out why, uppon starting core temp i saw that no matter what i did all the cores are stuck at 1.4046GHz. I am going to do a BIOS flash with the same bios and retry to put all the settings in order. Also the driver crash issue on GTX 590 is more annoying than ever! I will diable more or less everything and i will post the results if i manage to get it to work OK.
11-11-2011 07:20 AM
11-14-2011 02:07 PM
