Problems with stabilizing FX-9590 on Crosshair V Formula Z with watercooling
Diabblo13
hello
I have the following problem
My system always freezes. And only the reset button helps.
It happens when i play, run on the desktop or at the bootprocess.
There is no pattern award.
Produkt : Motherboard
Model : Crosshair V Formula-Z
[Mainboard]
Revision : 1.0
BIOS Revision : 2101
[graphic card]
Hersteller Grafikkarte : Gigabyte / Nvidia
Model : GV-N980G1 GAMING-4GD
Chipsatz : nVidia GM204
Treiber : 347.52 WHQL
[Prozessor]
Hersteller : AMD
Typ : FX-9590
Takt : 4.7 Ghz
[Ram]
Hersteller : G.Skill
Model : F3-2400C10Q-16GTX
Kapazität : 16GB
[hard disk]
Hersteller : Samsung
Model : MZ-7TE250BW Serie 840 EVO Basic SSD
Kapazität : 250GB, 512MB Cache, SATA III
system : Windows 8.1 64bit
psu : DARK POWER PRO 10 | 1000W CM
My Watercoolingsystem
1x pump aqua computer Aquastream XT
1X radiator 120
1x radiator 140
1x radiator 220
are to cool
1x fx-9590
2x 980gtx
1x nb from the motherboard
Cpu temp is max. 59 grad
should information be missing just ask.
with best great Niels M.
16 REPLIES 16
elesde
Hi there!
My first guess would be the RAM, on what frequency are you running it on?
The FX series is a bit moody when it comes to high frequency RAM 😕
Oh and what kind of PSU are you using to power that beast?
Diabblo13
hello
I've tested in 1600 and 2400.
Do I have a DARK POWER PRO 10 | 1000W CM
MeanMachine
Hi Diabblo13 and Welcome to ROG. Is this a new build?
Have you OCed at all,? if so, clear CMOS back to default, re-enter Bios and set for D.O.C.P in AI Overclock Tuner. (Allows the system to set the best initial parameters for CPU ratio,bus and memory) and leave the rest on auto.
Restart and conduct a stress test, first on your CPU using ROG Realbench or Prime95 and monitor your temps.
If and when you are stable at stock frequency, you can then tune for more performance.
Observe your Qcodes during post cycle and report any stop errors.
Report back your results at 4.7GHz and we can take it from there.
We owe our existence to the scum of the earth, Cyanobacteria
My System Specs:
MB:ASUS ROG Crosshair VII Hero/WiFi GPU:EVGA GTX 1080 sc PSU:Corsair AX-1200i
CPU:
AMD R7 2700X Cooler: Corsair Hydro H115i Case: Corsair Carbide 780t
Memory:G.Skill TridentZ F4-3200C14D-16GTZR SSD:Samsung 500GB 960 EVO M.2
[/HR]
Oekerman
I'm having similar issues with my FX-9590. My weak cooling and 750w PS isn't enough and ive found a stability with under clocking to 3.2-4.3 GHz to accommodate temps and my r9 290 has fans set to 100% without the side cover on. my radiator is set with fans both sides of back of case pulling in and 3 fans on top drawing air out with 2 fans on front drawing in also. With 3.8GHz at idle I get 34 degrees and running folding@home on mid i get 60-61 degrees. World of Warcraft gets 54-59 degrees. voltage seems to get sketchy above 4.5 GHz and above 61 degrees. Kind of a noob at this, but just sharing info might be helpful. I understand that this processor is designed to run around 5GHz, but for the sake of it lasting to next year when i can upgrade cooling and power 4.2 GHz is as far as i can push it without anomalies or voltage drops. Id be happy to share CPUID HWMonitor screenshots with you under similar circumstances to compare optimizing techniques.
Korth
Level 14
The Crosshair V Formula-Z supports DDR3-2400. The FX-9590 only supports DDR3-1866 - not sure if that's even an issue, an out-of-the-box stock limit or a hard technical one, I honestly don't know a lot about overclocking modern AMD parts. Processor spec of 220W TDP is no joke - more than many beastly GPU cards - I wouldn't expect the full 5.0GHz without serious cooling (59C is pretty awesome though).
Run memory burn-in tests to determine if RAM is the problem. Perhaps try reseating the RAM, then try remounting the processor? You might just have a bad electrical contact, it sometimes happens to the best of us lol. Perhaps do a clean (nuke-and-pave) Windows+Drivers reinstall if no hardware issues can be identified? If you've had sudden power interruptions or forced-shutdowns then your SSD may have lost/corrupted OS-critical data.
[/Korth]
blppt
Also note that the FX-9590 memory controller is only rated to do 1333 when you have 4 sticks of double ranked/sided ram in the system. Also of note, I have never been able to get my RAM running at 2133 to pass prime95 memory tests, despite it being rated 2133-10-10-11-30@1.65V---whether the cpu is overclocked OR running stock. Likely culprit is that they are (4) 8GB dual ranked ram sticks.
For reference, its 2 of these packages:
http://www.newegg.com/Product/Product.aspx?Item=N82E16820403007
Although I paid MUCH, MUCH less than what newegg is currently selling them for, LOL.
Diabblo13
Hi
Here are the BIOS settings after the cmos
more
Diabblo13
and so what exactly should I test?
