Problems installing A1 suite.
Bodmech
Hi
After following the clean up and install instructions I too am unable to install the upgraded A1 suite, I did have the original A1 from disk installed.
I am getting a window "you must reboot this system to complete a previous installation. After rebooting run the setup again".
This window pops up every time when trying to install A1 and still after rebooting and trying the clean up process over and over.
I have tried cleaning registry but cant seem to remove remnants of an old install.
Any help would be appreciated.
Thanks in advance.
4 REPLIES 4
HiVizMan
Level 40
http://rog.asus.com/forum/showthread.php?36977-How-to-Install-Ai-Suite-3!-(For-People-Who-Cannot-ins...
Did you follow this guide?
Bodmech
Hello, yes I followed the guide, tried several times.
as an update, I can install the older version of A1 suite from the setup DVD that came with the Gene board with no problems, I just cant get the new A1 to install.
I have tried numerous times uninstalling and using the cleaner and the install guide.
HiVizMan
Level 40
Then stick with the old one for now, and check back here in the forum and on the support page for your motherboard for a revised version. I know that the software guys are working on it.
Bodmech
Ok, thanks for your time.
