Problem with the driver for a system device called AMDA00
WebMaximus
Running Win7 64bit and looking in the Device Manager I have a yellow exclamation mark on a device called AMDA00 and the error says
This device is not working properly because Windows cannot load the drivers required for this device. (Code 31)
Is there a fix available for this problem?
4 REPLIES 4
WebMaximus
Knock knock...anyone home?
bch
Have you tried
http://www.asus.com/Motherboards/MAXIMUS_VI_FORMULA/HelpDesk_Download/
Windows 7 64bit
Utilities
ASUS_AMDA00_ACPI for Windows 7 32/64bit & Windows 8 32/64bit & Windows 8.1 32/64bit?
WebMaximus
Will give it a try, thanks!
WebMaximus
Just tried it but when launching the AsusSetup.exe file nothing happens and when trying to update the driver via Device Manager pointing to the folder where I extracted this new driver Windows tells me the best driver is already installed.
I think I skip this now and keep the device disabled instead, getting tired of trying to fix this issue now.
