Problem with my P5QD turbo
Retired
Not applicable
hello guys, i'm Kevin from Indonesia...i have some prblems with my P5QD turbo motherboard, i think my back panel is having a trouble especially for the speaker input, every time i restart my computer, the motherboard cannot detect the speaker, so i must pull out the speaker cable and plug it back into my back panel, it always happen when i turn off or restart my computer..has anyone have the same problem with me...?please help mee 😄 ...i'm gettin' confuse now..
xeromist
I'm not sure where the setting is but there should be a setting in the audio control panel (the driver control panel, not the Windows one) for jack sensing or detection. If you disable this then it shouldn't try to auto detect anymore.
Retired
Not applicable
oowww...okay i will try to search that..tqu
