Problem with intel NIC on Crosshair formula V
rogtor
Hello, I tried to update drivers but it did not work. The text that appears "The Installed version of Intel PROSet is normally supported for upgrade. You must uninstall it before Installing this version."
I have tried to uninstall the drivers in the computer manager but with no luck.
I get BSOD when I surf on YouTube or another webb site or program with high bandwidth uses.
I have been looking around the forum and tried some things but none have really helped me.
8 REPLIES 8
NemesisChild
Level 12
Do not uninstall in Device Manager, do it through the Control Panel (Programs & Features).
Intel i9 10850K@ 5.3GHz
ASUS ROG Strix Z490-E
Corsair H115i Pro XT
G.Skill TridentZ@ 3600MHz CL14 2x16GB
EVGA RTX 3090 Ti FWT3 Ultra
OS: WD Black SN850 1TB NVMe M.2
Storage: WD Blue SN550 2TB NVMe M.2
EVGA SuperNova 1200 P2
ASUS ROG Strix Helios GX601
I can't find the intels driver in Programs & Features.
I installed the latest driver that asus website gave me.
NemesisChild
Level 12
D/L the latest ProSet NIC driver from Intel's website.
Then, I would boot into safe mode and uninstall the current Intel NIC driver through Device Manager.
Boot back into Windows and install the new ProSet driver, see if that works.
Intel drivers should be uninstalled via Control Panel -> Programs -> Remove. They should be listed as "Intel Network Connections". Intel drivers 16.4 or 16.5 are free of the BSOD problem under heavy network load.
rogtor
I reinstalling Windows 7 and take the driver from intels website.
but thanks anyway.
I get no longer BSOD with 16.5 driver as klosz007 has written.
Retired
Not applicable
Hi there, my first post here...
Same problems for me when I try to copy heavy files (just like a dvd ISO) from a XP-based pc of my network to the 7-based pc with the Crosshair mobo. I get a BSOD "Driver IRQ NOT LESS EQUAL etc." in TCPIP.SYS.
I tried with latest drivers from Asus website (16.1) but didn't help, now I'm downloading the one's from Intel (they are quite smaller, about 30Mb vs more than 100Mb) but I can't find the Intel's drivers listed in Programs & Features... I have the italian version of Seven Home Premium 64bit.
Thanks in advance for the help, 🙂
Baio
EDIT: Sign added!
Silverstone Fortress FT02
AMD Thuban 1090T@WORK IN PROGRESS!! cooled by Noctua NH-D14
Asus Crosshair V (bios 0705)
2x4GB Mushkin Redline@WORK IN PROGRESS!!
PSU Corsair HX850W
Sapphire 5870 Vapor-X
X-Fi Titanium Fatal1ty Pro
Crucial M4 128Gb
600Gb WD VelociRaptor
Samsung 214T 21"
xeromist
Hi Baio,
It's generally recommended to remove old drivers first, but if you can't find them just try installing the new one and see what happens. As long as all of the necessary files and settings are overwritten properly by the new driver it will not be a problem.
Retired
Not applicable
Hi xeromist,
Thanks for your replay. It's a pity Intel's installer does not create an entry where it's supposed to be... also if the installer I dowloaded from their website does not install itself over the previous one!
So I unpacked it and found 3-4 uninstall programs, then I updated the driver through device manager... now it seems to work fine, I'll check in the next few days.
My advice: do not install network drivers by Asus website, but go with Intel's one!
Ciao!
Baio
