01-19-2018 06:12 PM
01-20-2018 01:06 AM
01-20-2018 06:54 AM
Silent Scone wrote:
That platform is not quite as good at handling higher density kits. You will likely need to relax sub timings from defaults. Try 2666 at the kits rated timings of 16-18-18-38 2T, firstly.
Tuning the VCCSA is key to finding stability on this platform, too. Especially with high density kits. Try VCCSA 1.15v and work up till 1.25v. Too much can be just as damning as too little voltage here. You will have to see what works best, every CPU is different. The same is applicable for VCCIO.
Also try increasing the DRAM voltage to 1.3v for that frequency.
If it proves too much trouble, return the kit and purchase one that is validated for your board.
01-20-2018 01:08 AM
01-20-2018 06:57 AM
Arne Saknussemm wrote:
When you set XMP profile for 3200 16-18-18-38...what happened...would the system boot?
What happens if you try G.Skills suggestion but with 1.3v or 1.35v
In BIOS...what is your VCCSA reading? SA voltage
01-20-2018 07:33 AM
01-20-2018 08:20 AM
01-20-2018 08:54 AM
01-20-2018 09:28 AM
Yeah system agent voltage...you can apply an offset of say 0.1v and then try 0.15....0.2...see if that gets you around the 1.1v (or higher if needed) mark and more stable.
There are also some options in the DIGI+ section you can try....set dram power to 120%...and phases to optimised
You can also add a touch of VDIMM...say 1.36...1.37v
01-20-2018 09:38 AM
