Problem wiht my Maximus Gene IV z start and reset led on, but wont start
hik0_seju
Greetings, I have a problem with my MOBO maximus gene Z IV, lit LEDs on and reset, but will not start my PC, I turn off the power supply and I reconnect, and it happens that the led "go_led" falls a while on a 5min maybe, the light turns off and on and reset, try enceder my PC and nothing happens.
And try to light with only the memory and the result is the same.
which can be HELP!
Nate152
Hello hik0_seju, welcome to the ROG forum.
When you try to start your pc what code does the led readout stop on? Look up that code in your manual, it can point you in the direction of the problem.
List your complete system specs and tell us what code it's stopping on please.
Hi! thx, the problem is my Power supply y dead!
